Acer Chromebook 15 C910-C453 Fan Replacement
  1. Acer Chromebook 15 C910-C453 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook 15 C910-C453 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook 15 C910-C453 Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook 15 C910-C453 Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
  6. Acer Chromebook 15 C910-C453 Fan Replacement, Fan: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the following Phillips #1 screws:
    • Two black 4mm Phillips screws located on the fan.
    • Four copper 4mm Phillips screws located on the heat sink.
  7. Acer Chromebook 15 C910-C453 Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the fan from the motherboard by pulling down on the wire connector with two iFixit Opening Tools.
  8. Acer Chromebook 15 C910-C453 Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the fan while unwrapping the black and white wires from around the fan.
    • Do not pull wires off of the motherboard.
    • Remove the fan.
Jacob Rakestraw
crwdns2935283:004/17/17crwdne2935283:0
419 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S15-G1, Banghart Spring 2017 crwdns2935289:0Cal Poly, Team S15-G1, Banghart Spring 2017crwdne2935289:0
CPSU-BANGHART-S17S15G1
crwdns2942667:0crwdne2942667:0 608
