Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement
  1. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement, Display Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement, Display Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement, Display Assembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 7mm screws.
    • iFixit's magnetic project mat is great for keeping the screws organized.
    • Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
    • If the back cover is hard to remove, carefully use a metal spudger to remove the back cover.
  2. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to unscrew the four 5.5mm screws from the screen brackets.
    • Use tweezers to set aside the ground tape (tan) and the electrical tape (black). This may need to be reconnected during reassembly.
  3. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to detach the webcam connectors from the motherboard.
    • Keep in mind that the black cable connects to the left pin and the white cable connects to the right pin.
    • There may be electric tape covering the connectors. Use tweezers to set aside the tape for reuse.
  4. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the display panel connector from the motherboard. The connector should slide out away from the motherboard.
    • Be sure to remove the connector evenly from the port.
  5. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the lid from the laptop, pivot each end on the hinge and lift the rest of the laptop up and away from the lid.
    • Remove the display assembly from the laptop case.
Thomas Carling
crwdns2935283:001/30/20crwdne2935283:0
570 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S17-G7, Lamothe Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S17-G7, Lamothe Spring 2020crwdne2935289:0
ERAU-LAMOTHE-S20S17G7
crwdns2942667:0crwdne2942667:0 1,025
