Simple and clear steps for replacing the cooling fan / CPU heat sink assembly on an Acer C720-2420 Chromebook.
Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
Use the plastic opening tool to carefully remove the bottom.
Remove the two 3.6 mm Phillips screws holding the battery in place.
Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
Remove the six 4.7 mm Phillips screws that secure the fan.
Disconnect these cables from the motherboard using the tweezers.
Pull out the fan.
