Acer Aspire V5-591G-75KE Disassembly
  1. Acer Aspire V5-591G-75KE Disassembly, Acer Aspire V5-591G-75KE Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-591G-75KE Disassembly, Acer Aspire V5-591G-75KE Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-591G-75KE Disassembly, Acer Aspire V5-591G-75KE Disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Close down the display and flip the device upside down.
    • Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
  2. Acer Aspire V5-591G-75KE Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire V5-591G-75KE Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the screws removed, flip the device right-side up and open up the display.
    • Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
    • Popping sounds are normal, but forceful prying can damage delicate components. Be especially careful near the USB and HDMI ports.
  3. Acer Aspire V5-591G-75KE Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire V5-591G-75KE Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
    • Do not yank the bottom casing off. There is a small speaker wire that connects it to the motherboard.
    • Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
  4. Acer Aspire V5-591G-75KE Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-591G-75KE Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-591G-75KE Disassembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
    • The entire bottom casing should lift with no resistance. If there is too much resistance, verify you removed all the screws, and run the plastic spudger tool around the face-plate again.
Tasier Hagler
crwdns2935283:010/18/17crwdne2935283:0
428 crwdns2915208:0crwdne2915208:0
UW Tacoma, Team S3-G5, Liner Fall 2017 crwdns2935289:0UW Tacoma, Team S3-G5, Liner Fall 2017crwdne2935289:0
UWT-LINER-F17S3G5
crwdns2935297:018crwdne2935297:0
Buna ziua , Se poate înlocui procesorul cu unul m-ai performant (Gen I9,I7 -14700 ,etc.) ? Care ar fi acesta ?Mulțumesc !
Lucian Icu - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,542
