Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement
crwdns2936621:0crwdne2936621:0
  1. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Cooling / Fan System: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Cooling / Fan System: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the Fan cable.
    • Remove the three screws from the CPU cooler and one from the Fan module.
    • When you change the Cooling system, you must clean the processor from old thermal compound and put new.
  6. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a lint-free cloth to clean the old thermal compound.
    • If the thermal compound is solidified, you can use a flat end of any plastic tool to scrape it off.
    • Use again cloth with isopropyl alcohol to clean the Thermal surface.
  7. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 3x Phillips screws and open the Fan case.
    • Use a soft brush and clean the Fan and the Cooler.
  8. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the same technic to clean the surface of the processor from the old thermal compound
    • Be carefully,if you don't want to break the CPU.
    • Dispense a small amount of thermal compound and gently smear it over the entire processor surface.
  9. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Careful install the Cooling system with even pressure from all sides, and the bead that you placed on the surface will spread over the entire contact surface.
ZFix
crwdns2935283:012/09/13crwdne2935283:0
194.715 crwdns2915208:0crwdne2915208:0
crwdns2935297:0330crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0326crwdne2931471:0
crwdns2935297:01.378crwdne2935297:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 3,361
