How to disassemble the laptop and replace the Wi-Fi (WLan) Half Mini PCIe card.
_____________________________________________________________________________________
crwdns2936621:0crwdne2936621:0
Turn off the laptop and remove the battery.
Remove two screws securing the Keyboard.
The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
Remove the Keyboard and disconnect the two flex cables:
Keyboard flex cable
Keyboard Light flex cable
Remove 4x phillips screws and disconnect:
Power On button flex cable
Touch pad flex cable
Remove 18x Phillips screws from the bottom cover.
Remove any memory SD Card from the Card reader.
Start opening with a plastic opening tool.
Carefully separate the upper cover and remove it.
Remove one Phillips screw, securing th WLan card and disconnect the two coaxial antenna cables.
Remove the Wi-Fi card.
