How to disassemble the laptop, clean or replace the Cooling system or the Fan and change CPU Thermal Compound / Grease. This will help you if your system overheads or switch off randomly.
____________________________________________________________________________
crwdns2936621:0crwdne2936621:0
Turn off the laptop and remove the battery.
Remove two screws securing the Keyboard.
The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
Remove the Keyboard and disconnect the two flex cables:
Keyboard flex cable
Keyboard Light flex cable
It would be helpful to have more info on how to remove the two cables. The larger one has a couple of clips that slide, but what exactly comes off? Do the plastic strips lift, or do the flat cables just pull out of them? Don't want to break something!
I watched several videos, many of which had the action hidden behind the keyboard. The larger ribbon pulls out of the strip after the two white clips on the end are moved. The smaller one has a black strip which lifts from the ribbon side, releasing the cable.
Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
Slide the drive to the left and remove it.
Remove 4x phillips screws and disconnect:
Power On button flex cable
Touch pad flex cable
Remove 18x Phillips screws from the bottom cover.
Remove any memory SD Card from the Card reader.
Start opening with a plastic opening tool.
After removing the 18x Phillips screws, the laptop is VERY fragile in the hinge area. The bottom cover will easily crack or break in the hinge area when opening the laptop with no screws, particularly the left side near the power button. Possibly this step should be revised to recommend opening the laptop 90 degrees before removing the 18x screws. Or, advise extreme caution when opening the laptop with no screws.
Hi, do you know where buy screws that you mention in step 4? “Remove 18x Phillips screws from the bottom cover.”
I am italian. Thank you anyway.
The laptop I have included 6x screws from inside and 16x screws from the bottom. This seems to be a minor variation from model to model.
Same with my model @sara Caruso. The six of them, and the two to release the keyboard, are shorter than the 18. All the screws had blue locktite on them.
Carefully separate the upper cover and remove it.
In my unit, there was also a screw holding the DVD drive in place, just toward the center from the drive itself. This screw also had to be removed to be able to remove the upper cover
Gently remove the HDD and disconnect the SATA cable from it.
Remove one Phillips screw, securing th WLan card and disconnect the two coaxial antenna cables.
Remove the Wi-Fi card.
Remove the Memory Cover.
Disconnect the Loudspeaker cable connector.
Remove two Phillips screw from the Mother board and from the Optical drive SATA adapter.
Disconnect the LCD Display flex cable.
Disconnect the DC Jack cable.
Carefully remove the Optical drive SATA adapter.
We will disconnect the battery cable when we pick up the board.
Carefully pick up the Mother board and disconnect the Battery cable.
Disconnect the Fan cable.
Unscrew the screws that hold the Cooling system to the Mother board.
Carefully lift the Cooling system right up.
Use a lint-free cloth to clean the old thermal compound.
Use again cloth with isopropyl alcohol to clean the Thermal surface.
Remove three Philips screws held the Fan shield.
Unstick the black tape that hold the Fan to the cooler.
Unlock the clip and open the Fan case.
Close the Fan system.
Use the same technic to clean the surface of the processor from the old thermal compound
Dispense a small amount of thermal compound and gently smear it over the entire processor surface.
Hello!
Is ist possible to installa SSD storage to the V5-571G without removing the SATA?
Thanks for your reply
The two clips push toward the space-bar part of the keyboard. There are further clips around the edge of the keyboard, but it can be removed by careful prying with a thin blade screwdriver.
ENT - crwdns2934203:0crwdne2934203:0
