Acer Aspire V5-571 Cooling System Replacement
crwdns2936621:0crwdne2936621:0
  1. Acer Aspire V5-571 Cooling System Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement, Keyboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement, Keyboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 Cooling System Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  3. Acer Aspire V5-571 Cooling System Replacement, Optical Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement, Optical Drive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement, Optical Drive: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
  4. Acer Aspire V5-571 Cooling System Replacement, Upper  Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement, Upper  Cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement, Upper  Cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  5. Acer Aspire V5-571 Cooling System Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully separate the upper cover and remove it.
  6. Acer Aspire V5-571 Cooling System Replacement, HDD (Hard Disk Drive): crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement, HDD (Hard Disk Drive): crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement, HDD (Hard Disk Drive): crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  7. Acer Aspire V5-571 Cooling System Replacement, Wi-Fi Half Mini PCIe card: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement, Wi-Fi Half Mini PCIe card: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove one Phillips screw, securing th WLan card and disconnect the two coaxial antenna cables.
    • Remove the Wi-Fi card.
  8. Acer Aspire V5-571 Cooling System Replacement, Mother Board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement, Mother Board: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement, Mother Board: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the Memory Cover.
    • Disconnect the Loudspeaker cable connector.
  9. Acer Aspire V5-571 Cooling System Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two Phillips screw from the Mother board and from the Optical drive SATA adapter.
    • Disconnect the LCD Display flex cable.
    • Disconnect the DC Jack cable.
    • Carefully remove the Optical drive SATA adapter.
    • We will disconnect the battery cable when we pick up the board.
  10. Acer Aspire V5-571 Cooling System Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pick up the Mother board and disconnect the Battery cable.
  11. Acer Aspire V5-571 Cooling System Replacement, Cooling System and CPU Thermal Paste Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement, Cooling System and CPU Thermal Paste Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the Fan cable.
    • Unscrew the screws that hold the Cooling system to the Mother board.
    • Carefully lift the Cooling system right up.
  12. Acer Aspire V5-571 Cooling System Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a lint-free cloth to clean the old thermal compound.
    • If the thermal compound is solidified, you can use a flat end of any plastic tool to scrape it off.
    • Use again cloth with isopropyl alcohol to clean the Thermal surface.
    • Remove three Philips screws held the Fan shield.
  13. Acer Aspire V5-571 Cooling System Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unstick the black tape that hold the Fan to the cooler.
    • Unlock the clip and open the Fan case.
    • Use a soft brush and clean the Fan and the Cooler
    • Close the Fan system.
  14. Acer Aspire V5-571 Cooling System Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-571 Cooling System Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the same technic to clean the surface of the processor from the old thermal compound
    • Be carefully,if you don't want to break the CPU.
    • Dispense a small amount of thermal compound and gently smear it over the entire processor surface.
ZFix
crwdns2935283:012/09/13crwdne2935283:0
195,252 crwdns2915208:0crwdne2915208:0
crwdns2935297:0330crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0328crwdne2931471:0
crwdns2935297:01,435crwdne2935297:0
Hello!
Is ist possible to installa SSD storage to the V5-571G without removing the SATA?
Thanks for your reply
lukasrohrer - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 63
crwdns2942667:0crwdne2942667:0 9,691
