Acer Aspire V5-131-2680 Touchpad Replacement
  1. Acer Aspire V5-131-2680 Touchpad Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure your laptop is powered down and completely closed before proceeding.
    • Turn your laptop upside down. The stickers should be facing up.
  2. Acer Aspire V5-131-2680 Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire V5-131-2680 Touchpad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To open the bottom compartment, put one finger underneath the laptop and firmly grab the compartment with your thumb.
    • You can also use both thumbs for more pressure.
    • Carefully slide the bottom compartment with your thumb until you feel it pop out of place.
  3. Acer Aspire V5-131-2680 Touchpad Replacement, Touchpad: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the twenty 6 mm screws using a Phillips #00 screwdriver.
    • Unplug the battery and disconnect all the components connected to the motherboard.
    • Pry open the bottom of the laptop using the pry tool.
  4. Acer Aspire V5-131-2680 Touchpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the larger ribbon cable that connects from the motherboard to the keyboard by gently pulling on the end that attaches to the keyboard.
  5. Acer Aspire V5-131-2680 Touchpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the tape that is holding the smaller ribbon to the touchpad. Gently disconnect the smaller ribbon by pulling on it.
  6. Acer Aspire V5-131-2680 Touchpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once both of the ribbons are disconnected, the side with the keyboard will detach from the rest of the computer.
    • Now we can move the keyboard side without the rest of the laptop.
  7. Acer Aspire V5-131-2680 Touchpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all of the M2 x 3 Phillips screws that are holding the keyboard in place.
    • Some screws will be located under a piece of tape. Remove the tape prior to unscrewing these screws.
  8. Acer Aspire V5-131-2680 Touchpad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the keyboard from the frame by pulling up on the keyboard.
    • With the keyboard out of the way, we will be able to access the touchpad.
  9. Acer Aspire V5-131-2680 Touchpad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire V5-131-2680 Touchpad Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the touchpad from the frame by pushing up on the touchpad.
Mauricio Moreno
crwdns2935283:009/26/22crwdne2935283:0
601 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 6-1, Adachi Fall 2022 crwdns2935289:0CSU Los Angeles, Team 6-1, Adachi Fall 2022crwdne2935289:0
CSULA-ADACHI-F22S6G1
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 259
