Your battery is not working? You feel like you are lost?You are wondering how could you possibly check on it or even change it? This guide will teach you how to locate the battery and how to remove it to be replaced.
crwdns2936621:0crwdne2936621:0
Start the process of removing the bottom cover of the laptop by unscrewing the 8mm screws in the top right and left corners.
Remove the remaining 9 visible screws, which are 5mm in length.
Towards the top right corner of the laptop, there is a rubber piece covering the final screw holding the cover on, as well as a set of pins. Use your fingernail to remove this piece of rubber, and then unscrew the hidden 5mm screw.
Going around the edges of the laptop, apply light to moderate amounts of pressure away from the laptop to unseat the cover so that it can be removed. Once you have removed the cover, place it face-up in a safe place to avoid getting the inside of the cover dirty.
Carefully unscrew the two 5mm screws holding the battery in place.
Carefully use light upward pressure to unseat the battery from the case, but do not pull on the cord or try and completely remove the battery from the case.
Finally, disconnect the battery from the motherboard by undoing the power connector. To undo the connector, simply apply light to moderate pull on the sides of the connector.
crwdns2935229:05crwdne2935229:0
Flawless! the harness on the replacement was a little long and lumpy, but the back went back on just fine.
I just can't get one of the screws out - by the sd card slot. Any suggestions?
Any good sources for the replacement battery?
Nice guide. Thanks. I have the same model. May I know if it’s normal for my laptop not to work if the battery is removed? I removed the battery pack because they are bulging and not charging anymore. Since it will still take me a long time to buy a replacement and I already have many works pending, can you help me make it work with just the adapter plugged in? I badly need to finish my projects.
