Removing the back panel gives access to most everything else in the laptop.
Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
Use a spudger to pry the panel up from the laptop case and remove it.
The laptop should now be open with the RAM and wifi chip now accessible.
Is the hard drive accessible for replacement from the bottom? I see black stuff over the drive with the WIFI cables going underneath. Is that removable so one can access the drive from the bottom, or is it accessible from under the keyboard?
