Acer Aspire TimelineX 4830T-6682 Optical Drive Replacement
  1. Acer Aspire TimelineX 4830T-6682 Optical Drive Replacement, Lower Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire TimelineX 4830T-6682 Optical Drive Replacement, Lower Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire TimelineX 4830T-6682 Optical Drive Replacement, Lower Back Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the single screw with a Phillips #0 screwdriver.
    • Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
    • The other way to remove the panel is by sliding it away from the laptop. The difficulty of sliding it depends on the condition of your laptop.
  2. Acer Aspire TimelineX 4830T-6682 Optical Drive Replacement, RAM: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire TimelineX 4830T-6682 Optical Drive Replacement, RAM: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire TimelineX 4830T-6682 Optical Drive Replacement, RAM: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After the panel has been removed, locate the RAM. It should be on the lower right.
    • There are pins around the RAM that need to be pulled back. After the pins are removed, pull the RAM chip towards you to remove it.
  3. Acer Aspire TimelineX 4830T-6682 Optical Drive Replacement, Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eleven screws that hold that back panel to the laptop using a J0 Phillips screwdriver bit.
  4. Acer Aspire TimelineX 4830T-6682 Optical Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire TimelineX 4830T-6682 Optical Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire TimelineX 4830T-6682 Optical Drive Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    $3.99
    • Place the laptop in the upright position, the lower front touchpad panel should be easily detatched at this point.
    • Remove the lower front touchpad panel by using an angled tweezers to disconnect the only wired tape connected to the motherboard.
  5. Acer Aspire TimelineX 4830T-6682 Optical Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next, disconnect the 4 wired tapes of the keyboard from the motherboard just like we did with the lower front touchpad panel.
  6. Acer Aspire TimelineX 4830T-6682 Optical Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire TimelineX 4830T-6682 Optical Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Finally, using an opening tool, gently pry along the edge of the keyboard to separate it from the laptop.
  7. Acer Aspire TimelineX 4830T-6682 Optical Drive Replacement, Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery will be on the side closest to the screen.
    • Gently lift it out. It will still be attached by white, red, and black wires.
  8. Acer Aspire TimelineX 4830T-6682 Optical Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire TimelineX 4830T-6682 Optical Drive Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the white plug, it should easily detach.
    • Remove the battery from the device.
  9. Acer Aspire TimelineX 4830T-6682 Optical Drive Replacement, Optical Drive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Elevate the optical drive to get a good grip, then slide the drive horizontally away from the laptop, disconnecting it from the motherboard
Jon Brunsell
crwdns2935283:007/10/19crwdne2935283:0
592 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 296
