If your WiFi module is malfunctioning use this guide to remove and replace the device, to do this you will need a replacement WiFi module, tweezers and a PH 1 Philips head screwdriver. This is a simple process and should not require any in depth knowledge of computers to perform.
Power down the laptop.
Turn the laptop over so the bottom is facing up and the battery is facing towards you.
The tab on the right is a locking tab. Slide this tab to the right to unlock it (the red should now be showing).
Slide the left tab to the left and hold it there.
While holding the left tab to the left the battery should easily pull out of the laptop.
Flip the laptop over and remove screws (PH#1, 8mm length) holding the back cover in place
Remove back cover from your laptop
Disconnect the two antenna cables from the WLAN board as shown below
Remove the screw(PH#1, 3mm length) holding the WLAN board to the laptop
Detach and remove the WLAN board from the WLAN socket
