Acer Aspire TimelineX 1830T-68U118 RAM Replacement
  1. Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the device's battery before beginning.
    • Turn laptop so under side is facing up.
    • Locate the hard drive door and unscrew the 5 screws using PH0 mm Phillips Head.
  2. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry open hard drive cover using the Spudger tool.
  3. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove screw attached to the hard drive using the PH0 mm Phillips Head.
    • The hard drive can now be removed from the device.
  4. Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Fan: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Fan: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Fan: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove battery before beginning.
    • Use a Phillips #0 screwdriver to remove the 5 screws from the bottom cover.
    • Pry open the cover using the Spudger tool.
  5. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the keyboard with a plastic opening tool or spudger.
    • There is a plastic film that needs to be gently peeled from the laptop base.
    • Use caution when removing the keyboard as it is fragile.
  6. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the 4 screws from the motherboard shield.
  7. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motherboard from the base of the laptop by unscrew the screw drivers using PH0 mm Phillips Head.
    • Carefully remove the charger attachment in the top left.
  8. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully remove the fan from the motherboard by detaching the plastic insert as seen in the pictures
  9. Acer Aspire TimelineX 1830T-68U118 RAM Replacement, RAM: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the motherboard, turn it over so that the back side is facing you.
  10. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To release the RAM from the motherboard, press both of the metal prongs on the sides of the RAM.
  11. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After RAM memory card is released from the motherboard, hold the RAM card on a 45 degree angle and remove the card.
  12. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Install your new RAM memory card following these steps in reverse.
Brenna Waterbury
crwdns2935283:009/19/17crwdne2935283:0
523 crwdns2915208:0crwdne2915208:0
Idaho State University, Team S4-G6, Watkins Fall 2017 crwdns2935289:0Idaho State University, Team S4-G6, Watkins Fall 2017crwdne2935289:0
ISU-WATKINS-F17S4G6
Stupid! you can remove the ram after step 2!!!
Erlend - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 634
