Before performing any repairs, make sure the laptop is fully powered off and disconnected from its charger. To repair most parts of the Acer Aspire TimelineU M5-481TG, it is necessary to first remove the keyboard. Be sure to wear a anti-static wrist strap during all laptop repairs. Prying open the keyboard must be done very gently and carefully to ensure that no wires are damaged.
With the laptop closed and powered off, place the laptop screen side down.
Turn the laptop so that the hinges are closest to you.
Remove sixteen 6 mm screws from the bottom of the laptop with the Phillips #00 screwdriver.
Flip the laptop over and open the lid.
Use the plastic opening tool with the half centimeter wide tip to gently separate the bottom case of the laptop from the keyboard.
Gently pull the keyboard upwards to a 45 degree angle.
Hold the keyboard open with one hand to extend the three cables (white, black and copper) still connecting the bottom of the keyboard to the back case.
Use your fingernail to flip up the small retaining flap of each zero insertion force connector and then gently pull each ribbon cable out one at a time.
Use both hands to remove the keyboard.
my problem is how to replace the keyboard not how to dismantle it
