Acer Aspire Switch 10 SW5-012-18MY Battery Replacement
  1. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the tablet from the keyboard.
    • You will not be needing the keyboard for this guide.
  2. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the opening tool to open the back cover. The opening tool should fit under the cover if you place it above the power button.
    • Lift this side of the back cover once the opening tool is inside the device.
    • Use the opening tool and your hands to gradually work around the edges of the cover.
  3. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the back cover off of the device with your hands.
    • You will need to use some force to pull off the back cover.
  4. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the piece of black, thin tape that is attached to the circuit board closest to the power button.
  5. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the opening tool to lift the ZIF connector holding the ribbon cable in place on the circuit board.
    • Pull out the ribbon cable from the circuit board. This cable should have the word "Audio" on it.
  6. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the piece of thin, black tape that is attached to the circuit board on the other side of the battery.
    • Use the opening tool to lift the black ZIF connector holding the ribbon cable in place.
  7. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Partially remove the piece of black tape that is holding the bundled cable connector to the battery in place.
    • Pull on the battery's bundled cable connector to unplug it from the circuit board.
  8. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #000 screwdriver, remove the 3 mm screw that is holding the battery in place.
  9. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the ribbon cable from the battery.
  10. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the battery from the device by lifting it up.
crwdns2935229:05crwdne2935229:0
Grecia Corrada
crwdns2935283:003/19/18crwdne2935283:0
1,155 crwdns2915208:0crwdne2915208:0
Baylor, Team S3-G3, Williams Spring 2018 crwdns2935289:0Baylor, Team S3-G3, Williams Spring 2018crwdne2935289:0
BU-WILLIAMS-S18S3G3
crwdns2936753:030crwdne2936753:0 78
crwdns2942667:0crwdne2942667:0 5,250
