Acer Aspire S7-392-6484 Motherboard Replacement
  1. Acer Aspire S7-392-6484 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire S7-392-6484 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all marked 3mm screws from the back panel of the device using a T6 Torx screwdriver.
    • Remove the orange marked screws using a T6 Torx screwdriver. Note that these screws are 4mm in length.
    • After all marked screws have been removed, lift up back panel to expose internal parts.
  2. Acer Aspire S7-392-6484 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the marked 1.5 mm screws with a Phillips #01 screwdriver.
  3. Acer Aspire S7-392-6484 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the cable located at the top of the battery. Be careful to pull the cable horizontally, not vertically.
  4. Acer Aspire S7-392-6484 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
  5. Acer Aspire S7-392-6484 Motherboard Replacement, Fan: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire S7-392-6484 Motherboard Replacement, Fan: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back panel by unscrewing all marked 3mm screws with a T6 Torx screwdriver.
    • Remove these screws with a T6 Torx screwdriver, but note that these feet screws are 4mm in length.
  6. Acer Aspire S7-392-6484 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire S7-392-6484 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the marked 2mm screws with a Phillips #01 screwdriver.
    • Remove the fan by disconnecting the marked tabs.
  7. Acer Aspire S7-392-6484 Motherboard Replacement, Solid State Drive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the marked 2mm screw with a Phillips #01 screwdriver.
  8. Acer Aspire S7-392-6484 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the hard drive by pulling it away horizontally from its connection.
  9. Acer Aspire S7-392-6484 Motherboard Replacement, Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all marked 2mm screws using a Phillips #1 screwdriver.
    • Disconnect the orange marked connectors.
    • The connectors will take a decent amount of force to disconnect. This will not damage your device, so use the necessary force to disconnect them.
  10. Acer Aspire S7-392-6484 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up on the motherboard to pull it out of the casing.
Nicholas Wise
crwdns2935283:002/14/18crwdne2935283:0
754 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G6, Eyestone Spring 2018 crwdns2935289:0USF Tampa, Team S2-G6, Eyestone Spring 2018crwdne2935289:0
USFT-EYESTONE-S18S2G6
Hi Nicholas.
I was wondering if you really changed yours or just opened it. I need to change now mine and I’m not sure that the new one will be able to read my SSD which is Raid 0 without losing my data… Acer is famous for its stupidity of having a 1 drive Raid 0,
Thanks
Mr Man - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 2,204
