In this guide you will be shown how to replace the motherboard in the Acer Aspire. The motherboard is the most essential part of a computer and is paramount to the functions of your device. To determine whether the motherboard needs to be replaced, please refer to the troubleshooting page of this device.
Remove all marked 3mm screws from the back panel of the device using a T6 Torx screwdriver.
Remove the orange marked screws using a T6 Torx screwdriver. Note that these screws are 4mm in length.
After all marked screws have been removed, lift up back panel to expose internal parts.
Unscrew the marked 1.5 mm screws with a Phillips #01 screwdriver.
Remove the back panel by unscrewing all marked 3mm screws with a T6 Torx screwdriver.
Remove these screws with a T6 Torx screwdriver, but note that these feet screws are 4mm in length.
Unscrew the marked 2mm screws with a Phillips #01 screwdriver.
Remove the fan by disconnecting the marked tabs.
Remove the marked 2mm screw with a Phillips #01 screwdriver.
Remove all marked 2mm screws using a Phillips #1 screwdriver.
Disconnect the orange marked connectors.
Lift up on the motherboard to pull it out of the casing.
Hi Nicholas.
I was wondering if you really changed yours or just opened it. I need to change now mine and I’m not sure that the new one will be able to read my SSD which is Raid 0 without losing my data… Acer is famous for its stupidity of having a 1 drive Raid 0,
Thanks
