If your laptop doesn't play sound, use this guide to remove and replace your speakers. For this guide, you will need a PH00 screwdriver head and tweezers.
Remove the twelve 5mm screws with a Phillips #1 screwdriver.
Remove the two Phillips #0 screws from the left speaker.
Remove the speaker.
Remove the two Phillips #0 screws from the right speaker.
Remove the black tape above the right speaker.
Remove the right speaker.
Remove the white connector above the black tape.
