RAM, or random-access memory, is an important component to keep your computer running smoothly. Occasionally, RAM can wear out or become unseated, and need to be replaced.
Remove the top and middle grips that conceal 3 additional screws.
Remove the (8) 10mm T9 screws.
Remove the (5) 6mm T9 screws.
Press in on the release levers on either side of the stick of RAM.
Carefully lift and remove the RAM.
