The Hard Drive is internal, and requires some disassembly to replace. Make sure you have a way to keep all of the screws you'll be taking out sorted, and be careful with the internal parts of the computer -- they can be fragile!
Remove the top and middle grips that conceal 3 additional screws.
Remove the 5 6mm T9 screws.
Remove the 8 10mm T9 screws.
Unscrew the four 4mm PH0 screws holding the hard drive in place.
Tilt the hard drive up and pull it away and out of its base.
