Acer Aspire R7-371T-72CF Power Port Replacement
  1. Acer Aspire R7-371T-72CF Power Port Replacement, Power Port: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire R7-371T-72CF Power Port Replacement, Power Port: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off your laptop and disconnect the power adapter.
    • Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
  2. Acer Aspire R7-371T-72CF Power Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your prying tool, carefully remove the back panel.
  3. Acer Aspire R7-371T-72CF Power Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire R7-371T-72CF Power Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire R7-371T-72CF Power Port Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the power connector, as shown on the left.
    • The power connector will be in the same location as where you normally plug the charger into the laptop to charge your device.
  4. Acer Aspire R7-371T-72CF Power Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire R7-371T-72CF Power Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire R7-371T-72CF Power Port Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the wiring from the motherboard, and pull out the rest of the wire carefully.
    • Make sure the wire is not caught on anything before pulling.
  5. Acer Aspire R7-371T-72CF Power Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the power connector by pulling upwards on the wires.
    • This may require a small amount of force, but should pop out with some pressure.
Ethan Frey
crwdns2935283:009/27/17crwdne2935283:0
117 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S8-G5, Banghart Fall 2017 crwdns2935289:0Cal Poly, Team S8-G5, Banghart Fall 2017crwdne2935289:0
CPSU-BANGHART-F17S8G5
What’s the part number for the power jack cable, and who sells it?
AcerFan - crwdns2934203:0crwdne2934203:0
What model is this? Is this the older (~2015) model with the small cylindrical charging port?
Sarah - crwdns2934203:0crwdne2934203:0
The associated part id numbers for the Acer R7-371t 45W DC Jack Cable are:
50.MQPN7.001
SIQDD0ZS8AD001
Unfortunately, I have found this part impossible to find in stock at any source.
rosemank - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,872
