Acer Aspire R7 Battery Replacement
  1. Acer Aspire R7 Battery Replacement, Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire R7 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire R7 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove six 6mm T7 screws.
    • Remove four 4mm T7 screws.
    • Remove two 10mm T7 screws
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining two10mm T7 screws.
  3. Acer Aspire R7 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire R7 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the battery ribbon connector
    • Remove the ribbon cable attaching the battery to the motherboard by carefully pulling it outwards
    • When using the spudger be careful around the motherboard as it can easily be damaged
  5. Acer Aspire R7 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire R7 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire R7 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 4.5mm #00 Phillips screws attaching the battery to the motherboard
    • Push the 4 retaining clips away from the battery
    • Carefully lift the battery from the motherboard
crwdns2935229:012crwdne2935229:0
F Fernandez
crwdns2935283:001/13/15crwdne2935283:0
435 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-4, Hickman Winter 2015 crwdns2935289:0USF Tampa, Team 3-4, Hickman Winter 2015crwdne2935289:0
USFT-HICKMAN-W15S3G4
What is the battery reference for replacement ?
skalpinou - crwdns2934203:0crwdne2934203:0
which battery model do I purchase for replacing on an Acer Aspire R?
Eddie - crwdns2934203:0crwdne2934203:0
hey how do you want då sel it for
Alex santos - crwdns2934203:0crwdne2934203:0
super tuto
Thanks
P.S : A have add a short comment on step 2.
Bests regards
Anthymoine - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 41,781
