Acer Aspire R7 AC Socket Replacement
  1. Acer Aspire R7 AC Socket Replacement, Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 AC Socket Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire R7 AC Socket Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire R7 AC Socket Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove six 6mm T7 screws.
    • Remove four 4mm T7 screws.
    • Remove two 10mm T7 screws
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining two10mm T7 screws.
  3. Acer Aspire R7 AC Socket Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 AC Socket Replacement, AC Socket: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire R7 AC Socket Replacement, AC Socket: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire R7 AC Socket Replacement, AC Socket: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the AC Socket ribbon connector
    • Loosen the ribbon connector using the plastic opening tool
    • Pull the ribbon connector away from the motherboard
  5. Acer Aspire R7 AC Socket Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire R7 AC Socket Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to pry up on the yellow tabs holding the Socket in place
    • There is two sided tape holding this component to the case
    • Once the tape on the Socket is loose, pull up and away from the case to remove it.
Andrew Rodiek
crwdns2935283:001/13/15crwdne2935283:0
601 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-4, Hickman Winter 2015 crwdns2935289:0USF Tampa, Team 3-4, Hickman Winter 2015crwdne2935289:0
USFT-HICKMAN-W15S3G4
crwdns2942667:0crwdne2942667:0 1,534
