Acer Aspire R5-571T-59DC RAM Replacement
  1. Acer Aspire R5-571T-59DC RAM Replacement, Back Cover Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire R5-571T-59DC RAM Replacement, Back Cover Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
    What's the best way to safely remove and replace the bottom cover to prevent bending and otherwise stressing the casing and ports as you wiggle it loose and set it back in place?
    Alberto Einsteino - crwdns2934203:0crwdne2934203:0
  2. Acer Aspire R5-571T-59DC RAM Replacement, RAM: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the protective covering away from the RAM using tweezers, or your fingers.
    Ustedes tienen esta. Tarjeta para laptop acer aspire r15 modelo n16p2. R5 571t 59DC
    solucioneschat - crwdns2934203:0crwdne2934203:0
  3. Acer Aspire R5-571T-59DC RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire R5-571T-59DC RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire R5-571T-59DC RAM Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    • When released, the RAM module will pop up at a slight angle.
    • Lift the RAM module to an angle of about 30 degrees and slide it out.
Kelly Johnston
crwdns2935283:001/25/18crwdne2935283:0
600 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S20-G2, Passmore Spring 2018 crwdns2935289:0USF Tampa, Team S20-G2, Passmore Spring 2018crwdne2935289:0
USFT-PASSMORE-S18S20G2
How many slots for RAM does this laptop have? Is there a soldered stick in one of the slots? Thanks!
crwdns2942667:0crwdne2942667:0 1,074
