Acer Aspire One ZG5 Internal Wireless Card Replacement
  1. Acer Aspire One ZG5 Internal Wireless Card Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Internal Wireless Card Replacement, Wireless Card: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
    • These screws are built into the panel and aren't meant to be completely removed.
  5. Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the panel and remove it from the case.
  6. Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two antenna cables from the left side of the wireless card.
  7. Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
  8. Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift up the left side of the wireless card and slide the card out of its socket.
  9. Acer Aspire One ZG5 Internal Wireless Card Replacement, Keyboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the netbook over and open the display so that the keyboard is facing you.
  10. Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are three tabs located on the top of the keyboard.
    • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
    • As you move to the next tab, ensure the previous tab doesn't reset itself.
  11. Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
    • There is a short ribbon cable connecting the keyboard to the netbook.
  12. Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
  13. Acer Aspire One ZG5 Internal Wireless Card Replacement, Top Case: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close the display and turn the ZG5 over so that the battery compartment faces away from you.
  14. Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove three 5.8 mm Phillips #0 screws from the bottom of the case
    • Remove three 3.9 mm Phillips #1 screws from the battery compartment.
    • Remove two 5.8 mm Phillips #0 screws from underneath the feet near the hinges.
  15. Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the netbook back over and open the display with the keyboard cavity facing you.
  16. Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip up the retaining flap on the trackpad ribbon cable ZIF connector.
    • Using the blue tab, pull the trackpad ribbon cable from its socket on the motherboard.
  17. Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five black 4.7 mm Phillips #0 screws from the metal casing.
    • Remove the single silver 4.3 mm Phillips #00 screw from the right side of the metal casing.
  18. Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Starting at the red rings along the hinge, insert a spudger or plastic opening tool into the seam between the two halves of the case.
    • Slide the spudger toward the front of the device, releasing the small clips that hold down the top case.
    • Gently lift off the top case.
  19. Acer Aspire One ZG5 Internal Wireless Card Replacement, Internal Wireless Card: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two antenna cables from the right side of the wireless card.
  20. Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 3.9 mm Phillips #1 screw from the wireless card.
  21. Acer Aspire One ZG5 Internal Wireless Card Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the wireless card to the right and slide it out of its socket.
crwdns2935229:05crwdne2935229:0
Doug Gallatin
crwdns2935283:010/05/10crwdne2935283:0
6,385 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-49, Amido Fall 2010 crwdns2935289:0Cal Poly, Team 7-49, Amido Fall 2010crwdne2935289:0
CPSU-AMIDO-F10S7G49
crwdns2935297:034crwdne2935297:0
Este modelo tiene dos tarjeta de red? Es que adentro tiene una y esa donde se quita la tapita es otra?
marvoly - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 24,912
