Acer Aspire One D257 Keyboard Replacement
  1. Acer Aspire One D257 Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put the netbook, so the back side is upwards.
  2. Acer Aspire One D257 Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the right lock to the right so the red filed is visible on the left.
  3. Acer Aspire One D257 Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now move the left lock which is spring loaded to the leftand keep it there. Then with the other hand remove the battery by pulling down.
    • When reassembeling the new battery push it up into the netbook and do lock the right by moving it to the left so the red field disappears.
  4. Acer Aspire One D257 Keyboard Replacement, Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire One D257 Keyboard Replacement, Keyboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the lid othe the netbook. Use the Jimmy from the upper left corner of the keyboard. Put it between the keyboard and th casing and move it to the right. It might help to use a metal spudger to push in the pins holding the keyboard in place.
    • Then move down along the sides where there is one pin on each side. After that twist the keyboard towards you.
    There are little spring loaded lock bolts. Push them away from the keyboard.
    darsie - crwdns2934203:0crwdne2934203:0
  5. Acer Aspire One D257 Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now open the brown connector so the flat cable is loose. Then you can remove the keyboard.
    Lets see, the most delicate operation of all- flexible flat cable removal- and you say open it till loose. How ? Is the type of retainer that moves backwards, flips up or has side clips. Guess wrong and you are buying a new motherboard. Of course that could be the point of the ommission
    John Dawson - crwdns2934203:0crwdne2934203:0
crwdns2935229:05crwdne2935229:0
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Claes
crwdns2935283:002/01/16crwdne2935283:0
3,422 crwdns2915208:0crwdne2915208:0
I lost the flat retaining of the keyboard, what can I use?
ciccio - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,107
