Acer Aspire One D257 HDD Replacement
  1. Acer Aspire One D257 HDD Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put the netbook, so the back side is upwards.
  2. Acer Aspire One D257 HDD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the right lock to the right so the red filed is visible on the left.
  3. Acer Aspire One D257 HDD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now move the left lock which is spring loaded to the leftand keep it there. Then with the other hand remove the battery by pulling down.
    • When reassembeling the new battery push it up into the netbook and do lock the right by moving it to the left so the red field disappears.
  4. Acer Aspire One D257 HDD Replacement, Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire One D257 HDD Replacement, Keyboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the lid othe the netbook. Use the Jimmy from the upper left corner of the keyboard. Put it between the keyboard and th casing and move it to the right. It might help to use a metal spudger to push in the pins holding the keyboard in place.
    • Then move down along the sides where there is one pin on each side. After that twist the keyboard towards you.
    There are little spring loaded lock bolts. Push them away from the keyboard.
    darsie - crwdns2934203:0crwdne2934203:0
  5. Acer Aspire One D257 HDD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now open the brown connector so the flat cable is loose. Then you can remove the keyboard.
    Lets see, the most delicate operation of all- flexible flat cable removal- and you say open it till loose. How ? Is the type of retainer that moves backwards, flips up or has side clips. Guess wrong and you are buying a new motherboard. Of course that could be the point of the ommission
    John Dawson - crwdns2934203:0crwdne2934203:0
  6. Acer Aspire One D257 HDD Replacement, Acer Aspire One D257 opening the hatch: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 5 screws marked with "Door".
  7. Acer Aspire One D257 HDD Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire One D257 HDD Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger or flat screwdriver to push down the hatch where it is marked "Door release".
    • Now you can carfully remove the hatch.
    • When reassembling the hatch look that the noses are aimed at the appropriate holes in the case, then you can press down the rest of the hatch onto the netbook.
    Push "down", through the laptop towards the back. You're literally (carefully) kicking out the back door. There's an arrow pointing towards the large screwdriver receptacle. Not that direction, as in pushing the receptacle sideways in the arrow direction. Stab the laptop.
  8. Acer Aspire One D257 HDD Replacement, Harddisk Drive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The hard disk drive is under the lighgrey casing and not screw to it.
  9. Acer Aspire One D257 HDD Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now push the HDD downwards with the finger through the hole.
  10. Acer Aspire One D257 HDD Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Sata connector from the hard disk drive.
    • Now you can connect any Sata-HDD or SDD.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Claes
crwdns2935283:002/01/16crwdne2935283:0
3 422 crwdns2915208:0crwdne2915208:0
crwdns2947412:07crwdne2947412:0
@Arctic W. Fox What steps are you missing?
Claes - crwdns2934203:0crwdne2934203:0
The HD is removed through the back - there are about 5 screws (marked "Door") that need to be removed once the keyboard is removed. :-)
basestationzero - crwdns2934203:0crwdne2934203:0
Thanks for the feedback, I added the steps at least in the German Guide do not know how long it takes for the steps to show up in the translated English Version.
Claes -
I opened mine using a fork and a multitool.
Jason Barrett - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 12,290
