This guide will help the user locate and safely remove the battery.
Place the computer on a flat surface with the bottom facing you.
Place a finger on the small tab on the left with the lock and unlock symbols.
Slide this tab to the unlock position.
Place a finger on the tab in the upper right corner.
Slide this tab to the right and hold it in that position.
Place your finger on the three lines in the middle of the battery while holding the tab on the right.
Push forward on the battery lines while holding the tab on the right.
