In this guide, you will remove the USB Port from the device by removing two screws and disconnecting the ribbon cable connecting it to the motherboard.
Remove eleven 4 mm Phillips #1 screws
Pull the backplate off using your fingers.
Remove the two screws holding down the USB Port.
Now that the port can be lifted up, remove the ribbon cable by using the sticker attached to it.
