Acer Aspire One Cloudbook 11 AO1-131-C7DW Speaker Replacement
  1. Acer Aspire One Cloudbook 11 AO1-131-C7DW Speaker Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire One Cloudbook 11 AO1-131-C7DW Speaker Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire One Cloudbook 11 AO1-131-C7DW Speaker Replacement, Back Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power the laptop off.
    • Flip the laptop over and position it so the opening faces you.
    • Remove the rubber foot located near the opening side of the device using tweezers.
  2. Acer Aspire One Cloudbook 11 AO1-131-C7DW Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire One Cloudbook 11 AO1-131-C7DW Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the five 5-mm screws using the PH0 screwdriver.
  3. Acer Aspire One Cloudbook 11 AO1-131-C7DW Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire One Cloudbook 11 AO1-131-C7DW Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire One Cloudbook 11 AO1-131-C7DW Speaker Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Identify the HDMI port located in the side of the laptop opposite to the power button.
    • Insert the plastic opening tool into the divet of the back panel located above the HDMI port.
    • Pry along the laptop frame until the back panel comes loose.
    • Do not pull the back panel too hard as the battery is still connected to the back panel and the motherboard. This can damage your device.
  4. Acer Aspire One Cloudbook 11 AO1-131-C7DW Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire One Cloudbook 11 AO1-131-C7DW Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the device so the opening faces you again.
    • Hold the back panel away from the laptop and remove the 4-mm screw using the PH0 screwdriver.
    • This screw is fastening the battery to the laptop.
    • Lift the back panel gently.
  5. Acer Aspire One Cloudbook 11 AO1-131-C7DW Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire One Cloudbook 11 AO1-131-C7DW Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the cable that connects the battery to the motherboard.
    • Detach the back panel, which still includes the battery.
  6. Acer Aspire One Cloudbook 11 AO1-131-C7DW Speaker Replacement, Speaker: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire One Cloudbook 11 AO1-131-C7DW Speaker Replacement, Speaker: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Position the computer so the opening of the laptop faces you.
    • Unplug the white plastic connector that has red, white, and black wires using tweezers.
  7. Acer Aspire One Cloudbook 11 AO1-131-C7DW Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unhook the speaker by sliding it to one side first and then by lifting it up.
    • The gray rubber ring may come off during this process. Insert it back onto the speaker if this happens.
    • Repeat this step for the other speaker.
  8. Acer Aspire One Cloudbook 11 AO1-131-C7DW Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the tape strips holding the wires to the metallic plate using tweezers.
    • Save the tape strips for the replacement of the new speakers.
  9. Acer Aspire One Cloudbook 11 AO1-131-C7DW Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the speakers.
Xiaochen Lin
crwdns2935283:009/11/17crwdne2935283:0
152 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team S1-G4, Bruce Fall 2017 crwdns2935289:0CSU Fullerton, Team S1-G4, Bruce Fall 2017crwdne2935289:0
CSUF-BRUCE-F17S1G4
crwdns2942667:0crwdne2942667:0 367
