If the life of your battery is significantly shortened, it may be damaged or old. This guide can help you replace the battery by yourself!
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Power the laptop off.
Flip the laptop over and position it so the opening faces you.
Remove the rubber foot located near the opening side of the device using tweezers.
Unscrew the five 5-mm screws using the PH0 screwdriver.
Identify the HDMI port located in the side of the laptop opposite to the power button.
Insert the plastic opening tool into the divet of the back panel located above the HDMI port.
Pry along the laptop frame until the back panel comes loose.
Rotate the device so the opening faces you again.
Hold the back panel away from the laptop and remove the 4-mm screw using the PH0 screwdriver.
Lift the back panel gently.
Unplug the cable that connects the battery to the motherboard.
Detach the back panel, which still includes the battery.
Flip the back panel so the battery faces down.
Remove the rubber foot with tweezers.
Remove the 5-mm screw that is located underneath the rubber foot using the PH0 screwdriver.
Lift the battery and detach it from the back panel.
Anyone have a link for this exact laptop battery please?
