Acer Aspire One 751h-1948 Display Replacement
  1. Acer Aspire One 751h-1948 Display Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close the laptop and flip it over to view the back of the laptop.
  2. Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unlock the right side of the battery by sliding the battery lock to the right. Then slide the left lock to the left and remove the battery.
  3. Acer Aspire One 751h-1948 Display Replacement, Network Card: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire One 751h-1948 Display Replacement, Network Card: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two Phillips #0 (M2-L2.5 mm) holding down the network card panel.
    • These screws don't come all the way out.
  4. Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the two connecting cables by lifting them up. They should unclip easily.
  5. Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screw Phillips #0 (M2-L3 mm) holding down the network card. Pull out the card.
  6. Acer Aspire One 751h-1948 Display Replacement, Hard Drive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the Phillips 0# (M2 L2.5 mm) screw and remove the cover panel.
    • These screws will not come out all the way.
  7. Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the hard drive by sliding it to the left and pull it out.
  8. Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the Phillips #0 (M2-L2.5 mm) screws.
  9. Acer Aspire One 751h-1948 Display Replacement, Keyboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire One 751h-1948 Display Replacement, Keyboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire One 751h-1948 Display Replacement, Keyboard: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to push in each of the four clips and carefully lift the keyboard.
    • Don't lift the keyboard completely so that you don't damage the ribbon cable underneath.
  10. Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • When you remove the keyboard, be careful not to damage the ribbon cable that attaches it to the motherboard.
    • Unplug the ribbon cable by gently lifting the black tab up. Then remove the cable.
  11. Acer Aspire One 751h-1948 Display Replacement, Display: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire One 751h-1948 Display Replacement, Display: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire One 751h-1948 Display Replacement, Display: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the SCD cable
  12. Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to remove all rubber pads covering the screws for the upper casing.
    • Then unscrew all the Phillips #0 (M2-L5 mm) screws under rubber pads.
  13. Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the upper casing from the display.
  14. Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew all the Phillips 0# (M2-L2.5 mm) on each side of the display.
  15. Acer Aspire One 751h-1948 Display Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the screen from the metal frame that secures it to the upper casing and remove the screen.
    • Be careful, the display is very sensitive.
Chris Bolton
crwdns2935283:003/22/17crwdne2935283:0
434 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S8-G2, Catania Spring 2017 crwdns2935289:0UMass Dartmouth, Team S8-G2, Catania Spring 2017crwdne2935289:0
UMASSD-CATANIA-S17S8G2
crwdns2942667:0crwdne2942667:0 416
