Power down the netbook by pressing the power button on the top left corner.
Close the netbook and flip it over so that the back is facing up.
Slide the button below the battery to the right while simultaneously pulling the battery out.
If necessary, remove the old battery and replace it with a new one.
Remove the screw at the bottom of the laptop.
Unclip the two metal braces that hold the RAM in place by pushing the metal clips outwards away from the RAM itself.
The RAM should pop up.
Take the replacement RAM stick and line up the the grooves on the RAM to the grooves on the netbook so that they will fit in flush.
Press down on the RAM stick and the metal clips will lock in to place.
