It’s recommended to change Acer Aspire One 722 batteries after approximately one year of use. Normally a fully charged Acer Aspire One 722 battery will support the system for 7 hours, but as the batteries’ lifetime goes down it needs to charge frequently. Take this precaution, if your battery gets swollen. But it’s better to replace the battery before it gets swollen.
Use this simple guide to replace your Acer Aspire One 722 battery. Follow these 5 easy steps which will take no longer than 3 minutes and restore your Acer laptop to like-new performance.
Power down the netbook by pressing the power button on the top left corner.
Close the netbook and flip it over so that the back is facing up.
Slide the button below the battery to the right while simultaneously pulling the battery out.
If necessary, remove the old battery and replace it with a new one.
crwdns2935229:012crwdne2935229:0
First rate easy to understand completed in less than a minute.many thanks
I find myself computer savvy. These steps jarred my memory. They were perfect.
Thank you, you are a hero of 2021.
Thank you. Simple, yes, but a little encouragement always helps.
