In this guide you will learn how to replace the RAM in an Acer Aspire M5-583P-9688 laptop.
Remove all 18 marked screws (2.12 mm) using a Phillips #1 screwdriver.
Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off.
Pull back the brackets holding the RAM in place and remove the RAM.
