Acer Aspire ES1-711-P1UV Hard Drive Replacement
  1. Acer Aspire ES1-711-P1UV Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the laptop face down on a flat, clean surface.
    • Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
  2. Acer Aspire ES1-711-P1UV Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
    • Be sure to evenly apply pressure when removing the back cover.
  3. Acer Aspire ES1-711-P1UV Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 5 mm screws located on either side of the battery.
  4. Acer Aspire ES1-711-P1UV Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
  5. Acer Aspire ES1-711-P1UV Hard Drive Replacement, Hard Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 4.5 mm screws that hold the hard drive in place.
  6. Acer Aspire ES1-711-P1UV Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire ES1-711-P1UV Hard Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the tabs holding the hard drive in place.
    • Remove the hard drive.
Lindsay O'Shea
crwdns2935283:003/22/18crwdne2935283:0
441 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team S17-G3, Blackburne Spring 2018 crwdns2935289:0Sam Houston State, Team S17-G3, Blackburne Spring 2018crwdne2935289:0
SHSU-BLACKBURNE-S18S17G3
crwdns2942667:0crwdne2942667:0 2,764
