You may need to replace the battery in your Acer Aspire ES1-512-C80E if you experience problems regarding the device’s power. To access the battery, the back cover of the device will need to be removed. The process of replacing the battery should take between 10-20 minutes.
Place the device upside down on a flat surface.
Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
Pry around the edges with a spudger to remove the back cover.
Using a Phillips #00 screwdriver, remove the four 1.2mm screws from the keyboard.
Using a spudger, go around the edges and pry off the keyboard.
Remove the ribbon cable connection from the keyboard.
Peel back the two pieces of tape to separate the keyboard.
Remove the keyboard from under the plastic covering.
Remove the silver plate back cover of the keyboard from the bottom base.
Remove the large silver plate from the keyboard.
The keyboard is removed and ready to be replaced.
Remove the two 1.2mm Phillips #00 screws securing the battery.
Use a nylon spudger to remove the battery from the clips that hold it down.
Remove the wired connection to the laptop by pulling the plug out of the motherboard.
Remove the battery from the laptop.
