This guide will help you replace the hard drive on your Acer Aspire ES1-512 due to damage or for improvement.
Remove the 18 Phillips #0 screws.
Remove the optical drive or its plastic slot.
Gently lift the keyboard assembly.
Gently lift the top case, paying attention to the two connectors.
Disconnect the two connectors.
Disconnect the battery by removing the two connectors located next to the motherboard.
Disconnect the connectors of the power input, power button, and HDMI port.
Remove the Phillips #0 screw from the hard drive mounting bracket.
Gently disconnect the hard disk by moving it outward.
Remove the mounting plate by unscrewing the Phillips #0 screw.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
