Acer Aspire E5-721-64T8 Touch Pad Replacement
  1. Acer Aspire E5-721-64T8 Touch Pad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the twenty-five 6mm Phillips #0 screws from the bottom panel of the laptop.
  2. Acer Aspire E5-721-64T8 Touch Pad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, lift up on the side opposite of the Ethernet connector.
    • With the plastic opening tool under the bottom panel, work your way around the perimeter until the panel separates.
  3. Acer Aspire E5-721-64T8 Touch Pad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 6mm Phillips #0 screws from the battery.
  4. Acer Aspire E5-721-64T8 Touch Pad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire E5-721-64T8 Touch Pad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery from the motherboard.
    • Pull the battery up and out of the laptop.
  5. Acer Aspire E5-721-64T8 Touch Pad Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire E5-721-64T8 Touch Pad Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 6mm Phillips #0 screws from the fan.
    • Disconnect the fan from the motherboard.
    • Remove the four 6mm Phillips #0 screws from the heat sink.
    • Lift and remove the heatsink assembly from laptop.
  6. Acer Aspire E5-721-64T8 Touch Pad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Wi-Fi card by pulling it from the motherboard socket.
  7. Acer Aspire E5-721-64T8 Touch Pad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the display cable from the motherboard.
  8. Acer Aspire E5-721-64T8 Touch Pad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the speaker from the motherboard.
  9. Acer Aspire E5-721-64T8 Touch Pad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire E5-721-64T8 Touch Pad Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to flip up the retaining flaps on the ribbon cable ZIF sockets.
  10. Acer Aspire E5-721-64T8 Touch Pad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire E5-721-64T8 Touch Pad Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to flip up the retaining flap on the black ribbon cable ZIF socket.
  11. Acer Aspire E5-721-64T8 Touch Pad Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard up from the narrow side and jiggle slightly so that way it doesn't get caught on the ports of the laptop case.
  12. Acer Aspire E5-721-64T8 Touch Pad Replacement, Touch Pad: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel the black adhesive film up.
  13. Acer Aspire E5-721-64T8 Touch Pad Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 6mm Phillips #0 screws from touchpad.
  14. Acer Aspire E5-721-64T8 Touch Pad Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to flip up the retaining flap on the touchpad ribbon cable ZIF socket.
    • Remove the ribbon cable from the ZIF socket.
  15. Acer Aspire E5-721-64T8 Touch Pad Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire E5-721-64T8 Touch Pad Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the touchpad up by the side closest to the middle of the laptop and pull up towards you to remove.
Ed Herrera
crwdns2935283:001/25/18crwdne2935283:0
390 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S7-G3, Passmore Spring 2018 crwdns2935289:0USF Tampa, Team S7-G3, Passmore Spring 2018crwdne2935289:0
USFT-PASSMORE-S18S7G3
crwdns2942667:0crwdne2942667:0 393
