Acer Aspire E5-571P-55TL Motherboard Replacement
  1. Acer Aspire E5-571P-55TL Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure that laptop is turned off.
    • Turn the laptop upside down with the battery facing you.
  2. Acer Aspire E5-571P-55TL Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the Spudger into the battery lock and slide it to the left until you hear the battery unlock.
  3. Acer Aspire E5-571P-55TL Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire E5-571P-55TL Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571P-55TL Motherboard Replacement, Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire E5-571P-55TL Motherboard Replacement, Keyboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove each of the eighteen 8 mm screws from the bottom of the laptop.
  5. Acer Aspire E5-571P-55TL Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire E5-571P-55TL Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire E5-571P-55TL Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully place your fingers underneath the top of the keyboard just below the screen.
    • Pull upwards until you can hear the keyboard click out of place.
    • Continue around the entire laptop, carefully pulling the keyboard and palm rest assembly slightly from the frame to reveal the ribbon connectors.
    • Don't pull the keyboard off the frame yet because it's attached by ribbon connectors.
    • After the keyboard is detached, unplug each of the three ribbon cables and remove the keyboard and palm rest assembly.
  6. Acer Aspire E5-571P-55TL Motherboard Replacement, CPU Fan: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire E5-571P-55TL Motherboard Replacement, CPU Fan: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before replacing the CPU fan, you'll have to remove the network card found below the fan.
    • Using a Philips #0 screwdriver, remove the two 3 mm screws from the corners of the Wi-Fi card.
    • Carefully lift the network card from it's slot, and disconnect the two coaxial cables.
  7. Acer Aspire E5-571P-55TL Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire E5-571P-55TL Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The CPU fan can be found in the upper left corner of the laptop.
    • Using a Phillips #0 screwdriver, remove the two 4.5 mm screws from the fan.
  8. Acer Aspire E5-571P-55TL Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire E5-571P-55TL Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to safely remove the fan plug from the motherboard. To remove the plug, gently push left.
  9. Acer Aspire E5-571P-55TL Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure that all fan wires are disconnected from the board.
    • Lift the curved end of the fan, and safely remove it.
  10. Acer Aspire E5-571P-55TL Motherboard Replacement, Hard Drive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the two 8 mm screws holding the hard drive carriage in place.
  11. Acer Aspire E5-571P-55TL Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire E5-571P-55TL Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully unplug the ribbon cable running across the hard drive carriage and place it to the side.
    • Remove the hard drive by sliding it to your right, away from the motherboard, next pull the hard drive towards yourself and away from the laptop.
  12. Acer Aspire E5-571P-55TL Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once again using a Phillips #0 screwdriver, remove the two 3 mm screws highlighted on each side of the hard drive case.
    • Open the hard drive case to replace the hard drive.
  13. Acer Aspire E5-571P-55TL Motherboard Replacement, Motherboard: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire E5-571P-55TL Motherboard Replacement, Motherboard: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a Phillips #0 screwdriver, remove the two 4 mm screws from the motherboard.
  14. Acer Aspire E5-571P-55TL Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire E5-571P-55TL Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire E5-571P-55TL Motherboard Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully disconnect the speaker connection to the motherboard.
  15. Acer Aspire E5-571P-55TL Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire E5-571P-55TL Motherboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire E5-571P-55TL Motherboard Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The last connection to the motherboard is the screen. Gently disconnect the cable from the motherboard.
  16. Acer Aspire E5-571P-55TL Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard up from the top right corner, and then pull it right to release it from the case.
Max Piekos
crwdns2935283:003/23/22crwdne2935283:0
459 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team B-1, Gurgel Spring 2022 crwdns2935289:0UMass Dartmouth, Team B-1, Gurgel Spring 2022crwdne2935289:0
UMASSD-GURGEL-S22SBG1
crwdns2942667:0crwdne2942667:0 490
