Acer Aspire E5-571 WiFi Replacement
  1. Acer Aspire E5-571 WiFi Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 WiFi Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
    On the E-572P the hdd and memory is accessed from the removable flap on the bottom of the laptop - do not try to take the keyboard off!
    Peter - crwdns2934203:0crwdne2934203:0
  3. Acer Aspire E5-571 WiFi Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery towards you to remove it from the laptop.
    A fost extrem de ușor de scos bateria Dacă toate ghidurile ar fi așa de explicite ar fi extraordinar
    Trasor - crwdns2934203:0crwdne2934203:0
  4. Acer Aspire E5-571 WiFi Replacement, Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
  5. Acer Aspire E5-571 WiFi Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire E5-571 WiFi Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire E5-571 WiFi Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
    • Be careful not to break the plastic clips.
  6. Acer Aspire E5-571 WiFi Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire E5-571 WiFi Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully flip up the white hinge. Detach the three ZIF ribbons connected to the motherboard.
    • Remove the panel with the keyboard and the touchpad.
    not a complete guide, there is more steps to disassembly keyboard
    darkman.lv - crwdns2934203:0crwdne2934203:0
  7. Acer Aspire E5-571 WiFi Replacement, WiFi: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the WiFi card on the motherboard.
  8. Acer Aspire E5-571 WiFi Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire E5-571 WiFi Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the two antenna cables shown.
    • Using a plastic opening tool, remove both antenna cables from the WiFi card by gently prying them up.
    • Black on left. White on right.
  9. Acer Aspire E5-571 WiFi Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire E5-571 WiFi Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire E5-571 WiFi Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove this 3 mm Phillips #0 screw and the WiFi card should pop up.
    • Make sure antenna cables are removed before removing the screw.
    • Gently lift WiFi card off of the motherboard.
crwdns2935229:09crwdne2935229:0
daniel sawyer
crwdns2935283:008/23/15crwdne2935283:0
2.602 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 4-2, Meier Fall 2015 crwdns2935289:0USF Tampa, Team 4-2, Meier Fall 2015crwdne2935289:0
USFT-MEIER-F15S4G2
crwdns2947412:07crwdne2947412:0
np. im glad it worked for you. could you post the exact model you have and was there anything I missed?
daniel sawyer -
Great guide. I would just like to mention a difference I found. My laptop had white connectors and the hinged lock latch was black. So I guess all assemblies aren’t identical. Also, the large connector for the keyboard did not have a locking latch. My model is an E5-571P manufactured 2014/09/15.
Dan O - crwdns2934203:0crwdne2934203:0
Hi, I want faster Wifi. Which Wifi card do I need to replace for a Acer Aspire e15 e5-571-58E6?
Patrizia Barberio - crwdns2934203:0crwdne2934203:0
Hi I just bought an upgrade, so I’ll tell you which one I got and if it worked when I get it in the mail in a few weeks.
Matt -
UPDATE: The card I bought was a “Fenvi MPE-AX3000H”, and it worked very well and was only about $26 on eBay.
Matt -
Hi! Can you tell me if the RTL8822CE will work with my Acer E5 571 33PQ?? If not, which dual-band wifi adapter does this laptop support?
kris redfield - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 7,741
