Without WiFi you can have a hard time getting connected to the internet. This guide will show you how to replace a broken internal WiFi card.
Flip the laptop upside down. Rotate it so the battery faces you.
Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
On the E-572P the hdd and memory is accessed from the removable flap on the bottom of the laptop - do not try to take the keyboard off!
Pull the battery towards you to remove it from the laptop.
A fost extrem de ușor de scos bateria Dacă toate ghidurile ar fi așa de explicite ar fi extraordinar
Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
Carefully flip up the white hinge. Detach the three ZIF ribbons connected to the motherboard.
Remove the panel with the keyboard and the touchpad.
not a complete guide, there is more steps to disassembly keyboard
Locate the WiFi card on the motherboard.
Locate the two antenna cables shown.
Using a plastic opening tool, remove both antenna cables from the WiFi card by gently prying them up.
Remove this 3 mm Phillips #0 screw and the WiFi card should pop up.
Gently lift WiFi card off of the motherboard.
crwdns2935229:09crwdne2935229:0
crwdns2947412:07crwdne2947412:0
Very well done - thank you!
np. im glad it worked for you. could you post the exact model you have and was there anything I missed?
Great guide. I would just like to mention a difference I found. My laptop had white connectors and the hinged lock latch was black. So I guess all assemblies aren’t identical. Also, the large connector for the keyboard did not have a locking latch. My model is an E5-571P manufactured 2014/09/15.
Hi, I want faster Wifi. Which Wifi card do I need to replace for a Acer Aspire e15 e5-571-58E6?
Hi I just bought an upgrade, so I’ll tell you which one I got and if it worked when I get it in the mail in a few weeks.
Matt -
UPDATE: The card I bought was a “Fenvi MPE-AX3000H”, and it worked very well and was only about $26 on eBay.
Matt -
Hi! Can you tell me if the RTL8822CE will work with my Acer E5 571 33PQ?? If not, which dual-band wifi adapter does this laptop support?
