Can't seem to charge your battery? It may be time to replace it. This guide will walk you through the simple steps to access and replace the battery from your Acer Aspire E5-571 laptop.
Flip the laptop upside down. Rotate it so the battery faces you.
Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
On the E-572P the hdd and memory is accessed from the removable flap on the bottom of the laptop - do not try to take the keyboard off!
Pull the battery towards you to remove it from the laptop.
A fost extrem de ușor de scos bateria Dacă toate ghidurile ar fi așa de explicite ar fi extraordinar
crwdns2935229:08crwdne2935229:0
Uh…this makes no mention of the keyboard. Why is this titled as a keyboard repair, when it simply removes the battery?
lets hope next time the “This guide is being worked on by hardworking students. “ the steps involve more then just removing the battery
