On the back of the laptop, there is a sliding lock. Push the slider and the battery will unlock
Remove the 1 screw just above the battery with a Phillips #1 screwdriver.
Remove the 17 Phillips #1 screws remaining on the back side of the laptop
Flip over the laptop, Using the spudger separate the body of the keyboard from the base of the laptop.
Carefully lift the keyboard and disconnect the 3 ribbon style connectors from the computers boards.
now the fan can be pulled from the laptop
Disconnect the 2 plugs remaining on the computer
Remove the last 2 #1 Philips screws from the body
Remove the 2 #1 Phillips screws, then slide the metal cover back and away
Remove the board from the laptop body, flip over for access to the ram
Press down on the spring clips on either side of the ram, It will unlock and can be removed
