Acer Aspire E1-572-6829 Battery Replacement
  1. Acer Aspire E1-572-6829 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before beginning, make sure the laptop is turned off and the charger is unplugged.
    • Flip the laptop over so that you are facing the back panel.
    • Locate the battery lock switch below the battery.
  2. Acer Aspire E1-572-6829 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire E1-572-6829 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire E1-572-6829 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the battery lock switch to the open position using your finger or a plastic spudger.
    • While holding this switch open, use your other hand to slide the battery out from the back of the laptop.
    • Your battery is removed. You can now let go of the lock switch.
    • To reinsert the battery, make sure that it's tabs are lined up with the laptop and that it is facing in the right direction. Then slide it straight back in without using the lock switch.
Lauren Donlan
crwdns2935283:003/13/23crwdne2935283:0
115 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-2, Petersen Spring 2023 crwdns2935289:0UMass Dartmouth, Team 2-2, Petersen Spring 2023crwdne2935289:0
UMASSD-PETERSEN-S23S2G2
crwdns2942667:0crwdne2942667:0 415
