Acer Aspire E1-531-2438 Wifi Card Replacement
  1. Acer Aspire E1-531-2438 Wifi Card Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire E1-531-2438 Wifi Card Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug and power down the device before removing the battery.
    • Turn the device over so the back side is facing up.
    • Using a spudger, slide the orange latch to the right. This will release the battery, which should pop up from the device.
    • Use two hands tilt the side of the battery closest to the orange latch upward as shown in the images.
  2. Acer Aspire E1-531-2438 Wifi Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tilt the side of the battery closest to the orange latch upward.
    • Lift the battery up and out of the device.
  3. Acer Aspire E1-531-2438 Wifi Card Replacement, WiFi Card: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire E1-531-2438 Wifi Card Replacement, WiFi Card: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the two 9mm screws on the access panel.
  4. Acer Aspire E1-531-2438 Wifi Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire E1-531-2438 Wifi Card Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire E1-531-2438 Wifi Card Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the indentation, pry open the access panel with your fingers or a spudger.
    • Remove the access panel to expose the hard drive, WiFi card, and RAM modules.
  5. Acer Aspire E1-531-2438 Wifi Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, disconnect the two antenna cables connectors on the WiFi card.
  6. Acer Aspire E1-531-2438 Wifi Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire E1-531-2438 Wifi Card Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the 3mm screw holding the WiFi card in place.
    • The card will then lift up after the screw is removed.
    • Remove the card by pulling out in the direction that the card is now orientated.
Jakob Rinkus
crwdns2935283:003/21/19crwdne2935283:0
965 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S8-G2, Bailey Spring 2019 crwdns2935289:0UMass Dartmouth, Team S8-G2, Bailey Spring 2019crwdne2935289:0
UMASSD-BAILEY-S19S8G2
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 1,123
