Acer Aspire E1-470P-6659 Cooling Fan Replacement
  1. Acer Aspire E1-470P-6659 Cooling Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the laptop and disconnect all device cords.
  2. Acer Aspire E1-470P-6659 Cooling Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over so the bottom is facing you.
  3. Acer Aspire E1-470P-6659 Cooling Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire E1-470P-6659 Cooling Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire E1-470P-6659 Cooling Fan Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your finger or a spuger to pull the battery release switch.
  4. Acer Aspire E1-470P-6659 Cooling Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire E1-470P-6659 Cooling Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire E1-470P-6659 Cooling Fan Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery from the laptop.
  5. Acer Aspire E1-470P-6659 Cooling Fan Replacement, Hard Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire E1-470P-6659 Cooling Fan Replacement, Hard Drive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove nineteen screws from the back panel using a Phillips #0 Screwdriver .
  6. Acer Aspire E1-470P-6659 Cooling Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire E1-470P-6659 Cooling Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire E1-470P-6659 Cooling Fan Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Run the plastic opening tool across from one corner to another along the edge.
    • Separate the keyboard panel gently.
    • Lift the keyboard slowly from the laptop but do not lift completely because there are ribbon cables attached.
  7. Acer Aspire E1-470P-6659 Cooling Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire E1-470P-6659 Cooling Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the two keyboard assembly ribbon cables from motherboard.
    • To release small ribbon cable, use spudger or fingers to flip gray bar along edge over.
    • To release larger ribbon cable, use pry tool or spudger to slide white plastic clip forward.
  8. Acer Aspire E1-470P-6659 Cooling Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull up the release tab beside the hard drive.
    • Disconnect portion of ribbon cable that is covering the hard drive.
    • Handle the ribbon carefully. Do not break the metal contact.
    • While reconnecting the ribbon after replacing a new hard drive, face the blue side with a label up. Make sure the black line beside the sticker is not crooked, so that the ribbon is tight.
  9. Acer Aspire E1-470P-6659 Cooling Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the hard drive screw using Phillips #0 Screwdriver.
  10. Acer Aspire E1-470P-6659 Cooling Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the hard drive out gently. Be aware that it is connected to the adapter.
    • Gently remove adapter by pulling on both ends simultaneously to separate it from the hard drive.
  11. Acer Aspire E1-470P-6659 Cooling Fan Replacement, Motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire E1-470P-6659 Cooling Fan Replacement, Motherboard: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire E1-470P-6659 Cooling Fan Replacement, Motherboard: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove additional screws that can be found on the motherboard.
    • Remove the green wifi card from motherboard.
    • Use spudger to disconnect the fan and motherboard from laptop.
  12. Acer Aspire E1-470P-6659 Cooling Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire E1-470P-6659 Cooling Fan Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cable attached to motherboard.
    • Gently lift and remove the motherboard from the laptop.
  13. Acer Aspire E1-470P-6659 Cooling Fan Replacement, Cooling Fan: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire E1-470P-6659 Cooling Fan Replacement, Cooling Fan: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the motherboard and fan piece over.
    • Remove the four screws using the Phillips #000 Screwdriver.
  14. Acer Aspire E1-470P-6659 Cooling Fan Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire E1-470P-6659 Cooling Fan Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire E1-470P-6659 Cooling Fan Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the motherboard over and slowly remove the tape holding the cooling fan down.
    • Use a spudger to remove the top of the fan from the base of the fan.
    • Remove the cooling fan component from both the tape and the motherboard.
Faith Lobaton
crwdns2935283:010/22/18crwdne2935283:0
518 crwdns2915208:0crwdne2915208:0
UC Davis, Team S4-G5, Lore Fall 2018 crwdns2935289:0UC Davis, Team S4-G5, Lore Fall 2018crwdne2935289:0
UCD-LORE-F18S4G5
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 513
