Acer Aspire E 11 Battery Replacement
  1. Acer Aspire E 11 Battery Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire E 11 Battery Replacement, Lower Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the thirteen 6.2mm Phillips #1 screws located on the bottom of the device.
  2. Acer Aspire E 11 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire E 11 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire E 11 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the back panel using a plastic opening tool. Slowly make your way around the device until the back panel comes off.
  3. Acer Aspire E 11 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire E 11 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press and hold the small black button located on the motherboard just above the battery for five seconds.
  4. Acer Aspire E 11 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire E 11 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire E 11 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using two plastic opening tools tightly grab the connector going from the battery to the motherboard and pull to unplug.
  5. Acer Aspire E 11 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire E 11 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire E 11 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew two 6.2 mm Phillips #1 screws on the right and left sides of the battery.
  6. Acer Aspire E 11 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the battery by lifting it out of the casing.
crwdns2935229:09crwdne2935229:0
Carlos Rodriguez
crwdns2935283:002/04/16crwdne2935283:0
435 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 16-1, Blackwell Winter 2016 crwdns2935289:0USF Tampa, Team 16-1, Blackwell Winter 2016crwdne2935289:0
USFT-BLACKWELL-W16S16G1
crwdns2947412:05crwdne2947412:0
Excellent instructions, very precise and easy to follow. Great job!!!!
[deleted] - crwdns2934203:0crwdne2934203:0
Can I remove the battery and use only the ac adapter to power it? Will it work and not cause damage to the unit?
json_viray - crwdns2934203:0crwdne2934203:0
when you take the battery out it works ok and when you put the battery the orange light when take out the battery its fine could it be the battery or board connector
steve varney - crwdns2934203:0crwdne2934203:0
when battery is out it works fine when connect out and orange and blue light come on then no display remove battery every returns to normal
Thanks - battery replacement carried out successfully by a technical incompetent! This step-by-step guide is much clearer and easier to follow than a video - wish there were more like this out there.
willstac1 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 11,192
