Acer Aspire 8735G Memory (RAM) Replacement
  1. Acer Aspire 8735G Memory (RAM) Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before proceeding, power down your Laptop and remove the power cable.
    • Close the display and lay it on a flat surface, top-side down.
  2. Acer Aspire 8735G Memory (RAM) Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unlock the battery by sliding the battery lock to the unlock part.
  3. Acer Aspire 8735G Memory (RAM) Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the middle lock to the right and the battery will pop up.
  4. Acer Aspire 8735G Memory (RAM) Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you want to replace the battery and nothing else then now is the time to do so.
    • Once the battery hatch is unlocked you can now safely remove the battery.
  5. Acer Aspire 8735G Memory (RAM) Replacement, RAM: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Philips J1 driver to remove eight screws securing the bottom case.
    • Remove all of the 8 screws. After that you are in.
  6. Acer Aspire 8735G Memory (RAM) Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now try to spot the Memory, which is here indistinguishable as a red circle.
  7. Acer Aspire 8735G Memory (RAM) Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Don't remove the ram before pushing the pins.
    • After the previous step, remove the ram by pushing the pins holding it outwards.
  8. Acer Aspire 8735G Memory (RAM) Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you need to change your memory and nothing else then now is the time to do so. The Acer Aspire 8735G takes DDR3 SO-DIMM ram, upgradeable up-to 8GB.
    • After that the pins jump up and you can carefully remove the ram.
Regome
crwdns2935283:001/20/23crwdne2935283:0
794 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 172
